2010 touring exhaust
wondering if anyone knows.......i have a 2010 SG...i like the D&D Boss full system....D&D sells a 2010boss exhaust for the street glide with the newly placed and sized o2 sensors......but from what i have read, the (power commander v)pcv and auto tune will need the older version 18mm o2 sensors......so D&D says if you are going to use the pcv...buy the 09 boss pipe with the older (pre-2010) bung location and size. Does anyone think that this will adversely affect the ecu or that there will be problems?
Am i better off simply getting a slip-on for now......problem is the heat coming off the pipes is crazy HOT! with the cat in the head pipe.
I heard that zippers suggestes the older style set-up also....untill their product works with the 12mm o2 sensors.....
Anyone who knows please shed some light....
If you use the old sensors, you will get a code that the O2 heaters are not working. Also, the 2010 calibratons are set-up to work with the new O2 sensor placement and close mounted CAT, and there may be issues moving them.
What would probably work is to use the new sensors, but make an adaptor to connect them as the PCV needs.
Or, you could use a tuner like the SEST or TTS which works with the OEM sensors no problem.
--Gary
--Gary
Lose the Cat
--Gary
--Gary
If the person does not know the operating temps of the o2 sensors could he take an IR Temperature gun and measure the heat where the sensors are now on a 2010 Tri Glide and weld the bungs in one of the pipes close to the head as the 09 have them.
I don't know which cylinder pipe has the 09 sensors! Does it make a difference which cylinder pipe you welded the bungs into. I believe they are near the front cylinder on the 09's maybe you could tell me. I would assume if you took the IR gun and found the sweet spot on the pipe "same temperature as where the o2 sensors are now in the head pipe" and welded in the bungs the ECM would read them just as where they are located now.
My Tri is burning me up and I can't do any mods to cool it down. Straight up if I move the 12mm o2's up in the head pipe do you think the ECM will read them the same. I know the o2 wires will reach for the rear cylinder pipe but don't know if they will be long enough without soldering a splice to reach the front cylinder. I got to get that cat stuffing out of there and get my AFR richened up.
The 2010 o2 sensors are a 4 wire, self-heated design, that generate heat from the bikes electrical system.... that is why they are further downstream than the 09 touring
The 09 and earlier 2 wire system is heated from the exhaust system, that is why they are near the exhaust port.
Each cylinder has it's own o2 sensor, the rear cylinder is on the top pipe, the front cylinder is on the bottom pipe....
This is merely a suggesstion, but to maintain the integrity of the system, without having to manipulate wiring, modify headpipes, do sample temperature tests to id a "Sweet Spot", why don't you guys do some homework on the SEPST or TTS Master tune....
It is a VERY SIMPLE, extremely flexible tuning TOOL....
I am not knocking the PC V, but as it stands, it is not compatible for the 2010 Touring models.... Different pin-out...
o2 school
You guys are what make this forum worth its salt, thanks again!
All touring bikes for 2010 come with the cat. In 09 only the California and CVO's had the cat. Liquid cooled would be an improvement over the toaster oven 2010 Triglide I have.
