O6 Classic Went Dead
Was just out for a ride and stopped to fill up the gas tank. Shut off the bike. Filled the Gas tank Went to re-start and nothing at all...no power what so ever, have checked battery connections, ground connection to the starter solenoid,all ok...was told about a circuit bracker near the battery...waited 30 minutes...still nothing...checked all fuses...all ok...even unpluged the TSSM and re-pluged it in....still nothing...anyone have any ideas what so ever as to whats going on???
RE: O6 Classic Went Dead
Roger,
Please clarify. When you say no power do you mean 1)no lights etc or 2)bike will not turn over.
If #1, check maxi fuse behind left side cover, also check voltage at battery.
If #2 check starter, starter button, kill switch, connections to starter, main ground from starter bolt to battery ground.
Hope this helps.
Tom
Hope this helps.
Tom
