error 280 with TTS master tune
Hi every one, I hooked up my master tune and pressed "Get ECM Info" I got the info and status showed unlocked. I went to save ECM Calibration, it started then asked for save file name. It got to 40% and said installing bootloader then gave me Error 280 and said quiting. Any ideas. Thanks, adown
EDIT: Never mind. I used my macbook running XP PRO (through Parallels)and was getting the error. I took my HP laptop out and had no problems. Funny, I've never had any problems running windows programs before. Is there any way to check my download other than the "Download OK" after it was done? Thanks again, adown
PS: if any one else prefers their Mac and figures this one out, please let me know
This is almost always due to a non-compatible USB serial adapter. There is some additional info on this in thread https://www.hdforums.com/forum/elect...e-tuner-4.html see post 31
Suggest using the TTS USB serial adapter, as it works well with all windows OS. There may be others as well, someone may chime in with what works for them.
OK, now I see you were running a XP on a Mac under parallels. The problem may be related to how your particular USB adaptor works in that environment.
--Gary
