PC3- what is firmware?
I have an 07 Road King that I've put a PC3 and Vance and Hines Pro Pipes on. From day one I've had a "hiccup" or "coughing" phenomenon at low cruising RPM's. I got a new map from Fuelmoto that didn't help, but Jamie also suggested that I upgrade the "firmware" which according to some posts here on the forums are supposed to help with the hiccupping phenomenon. I was able to figure out how to download the new map, but I have no idea what the "firmware" is or how to update it. Any assistance would be appreciated.
HF
HF
Download the Harley firmware from Power Commander.
http://www.powercommander.com/powerc...downloads.aspx
Connect your computer to the PC3 open the software and click on "Tools" then "Upgrade Firmware". Point to the file you downloaded and follow screen instructions.
OK, I'm frustrated. I can't get the firmware to go onto the power commander. I don't know what I'm doing wrong. When I attempt the update, it says "init. Data Error". I have no idea what this means or what I'm doing wrong. I've saved the update from the web site, but I can't get it to go onto the PC3. I've been able to download a map, just can't get the firmware for some reason.
