2005 Anniversary Fatboy Dyno runs
I have just had my 2005 anniversary fatboy 95 ci dynoed at my local dealer.
attached are the duno runs and data on torque. The only changes from stock are Kuryakyn twin velocity air cleaner and V&H staggered big shots. Could someone advise me if the graphs/data looks good or needs to be adjusted.
The map i installed ( I have a sert) is map 127hp103-a1.mt5 with the following mods
Add about 5 or 6 to the number in the 0 and 2% throttle columns in the RPM ranges of 500 to 4000 in the VE table for front cylinder. For rear cylinder VE add 7 to the total number. What I am saying here is if the cell has a 62 in it, just add five to it to make it 67. In the AFR table, you will see highlighted in red the maxed out AFR of 14.5 in a bunch of cells. Change all of them to 14
