Fat bob deccel pop
Fat bob deccel pop
Searched the forum and didn't find an answer for this. I have an '09 Fat Bob. I put on a Vance & Hines big radius 2-1 and a SE heavy breather. The local Harley shop "installed" a SE super tuner and dyno'd the bike. When I got the bike back it now constantly pops and backfires on all types of deccels. I checked the exhaust gaskets and saw no sign of leakage but replaced them anyway with no change. I called the shop and they said they did their best to try to "tune out" the popping but it's the fault of the pipe. I find this hard to believe and can't wait to pick up the software and start doing my own tuning. Anybody out there have this combination of pipe, air cleaner and super tuner????? What are your results?????
Hi, How many miles are on your bike? Some shops don't like to do a full tune on a bike with under 1k miles on it - they'll just do a rough tune without lots of high rpm runs to prevent improper break in and then get the bike back after 1k to do the full tune. Whatever the case may be, that should be a condition that can be fixed with that tuner. It's a pretty simple deal to add fuel to the proper level from idle to about 3k rpm's at 0 throttle. That right there would probably fix it.
I had similar problem when I got my pipes (python dual staggerds with SERT). Asked on this forum and the resounding answer was not all people/shops know how to tune and that that is very operator dependent. I researched and went to a different shop, got it dyno'd and everything was running really lean. They fixed it and a rarely get a pop now.
I think you should take it to Calgay Harley Davidson. They really have their act together there. If there's something wrong they'll fix it, or will give you a proper explanation about what is wrong. I was impressed with their level of service when I took my Road Glide in when it had the front end noise.
