sert disc
sert disc
Bought my bike in Feb and had a SE Filter and SERT along with SE slash downs installed. I was looking at the SERT package and found that the disc package was never opend. The box with the cables was open, just not the disc. Could they have actually installeded the SERT without opening and using the disc?
RE: sert disc
ORIGINAL: rmacnh
RE: sert disc
Installing a SERT is not correct terminology even though many dealers use it. SERT is Screaming Eagle Race Tuner and it consists of the little black box, which is the interface unit that stores your VIN, two cables and some software. Nothing from that package is actually installed but a MAP is downloaded from the computer software through the interface box into your ECM. The cables and black box are disconnected from the bike when done, and the plug cover is put back on and stored neatly.
Hopefully your dealer gave you a copy of the map they loaded or told you the name of the standard map they loaded.
bloomington g
08-06-2011 12:53 PM
