SERT map help
SERT map help
I have a 2004 Dyna FXDi with a SERT, Rinehart 2-1 and a Arlen Ness Stage 1 intake. The rest of the bike is stock. I am looking for anyone with a SERT map that would fit this build.
I tried Latus HD, they dont have one.
I think I am going to use the one from Harley for the Stage 1 intake and Slip-ons until I can get the bike tuned within the next week or 2.
Does anyone have any thoughts or suggestions on this?
Thanks in advance.
Thanks in advance.
I think installing a stage 1 SE slipons and SE AC basic map is the best you can do unless someone is willing to give you their expensive Dyno map for your specific parts. Plus there’s not much difference in the parts you are using verses the SE slipons and SE AC to require serious tweaking of the basic stage 1 map. What you will likely find is that you will need to tweak the stage 1 map to reduce decel pop or erratic slow speed behavior for any combinations of parts with the canned SE stage 1 map.
Ultra_RB
The Dyno Room
07-15-2018 02:28 AM
