o2 sensor upgrade
There are "wide band (very expensive) and wide bands(expensive and what most sell for this application) and switches (what we have). They all work fine. Just have to be applied correctly.
The TTS uses the stock O2 sensors, which are really more like "on-off", with a small + -range to do a perfect job.
Using this tuner it looks at how much fuel the ECM puts in to get closed loop (14.6) across the board. It then uses this to figure out the VE tables for each cylinder. You can then, for the running tune, put in the numbers you want (here is where the cooler running comes in) the AF ratio table in every spot to be. If the ECM knows the VE for each spot and you put in what you want the AF ratio to be, it can figure that.
And it will do that.
Keep it simple.
Keep it simple.
Mr.Softy
01-25-2013 10:20 AM
cruiser85257
27
01-31-2008 06:37 PM
