AF Ratio adjust vs parade download
I'm having heat issues.....not a huge deal, but cooler would be better.....My 1st thought is to get the Harley parade download that shuts off one cyclinder. Or just tweak the AF ratio numbers at idle.(I have a SERT)....
Any thoughts or anyone who has just adjusted the AF ratio and would like to share their numbers?
06 SG
SERT
V&H Classic slipons
Arlen Ness Big Sucker stage 1
06 SG
SERT
V&H Classic slipons
Parade Download????? It's called EITMS (Engine Idle Temperature Management System), and unfortunately, you can't install it if you are running SERT 4.77....
If you have a SEPST (SPX Version) or TTS, then you can enable or disable the EITMS via your Tuner file....
As far as adjusting your AFR's... As long as your VE's are synchronized to the target AFR, then you can adjust the AFR cells in the 0% to a workable desire...
Right now, the baseline cells in that area are set from 13.9 - 14.4 (141NR***)....
