'o6 Heritage Classic backfire
I have an '06 Heritage Classic w/ Screaming Eagle Pro II slip ons, Screaming Eagle air cleaner kit and the Stage 1 download. I am experiencing backfiring at deceleration. Have 800 miles on in. Any thoughts on this? The dealer said it is normal with these kind of pipes. Has anybody else experienced this? It isn't bad or even offensive just don't want to damage my new baby.
RE: 'o6 Heritage Classic backfire
I have the Screamin Eagle Pro Performance Slash downs on my RK which would be like your Pro II's. I will get an occaisonal pop on decel or when shifting but not that often. I have a SERT which was used to tune my bike. I decided I would rather spend a little extra money and get the SERT rather then waste money on the download and still end up buying a SERT. Everything I read said the downloads make the bikes run too lean.
Your dealer is full of BS...Yeah it,s normal if ya don't know how to fix it......Does your bike have the 8 degree injectors??? anyway it shouldn't do that.....I had to get a PC III from Fule Moto, He loaded a can map works great 3900 mi. I'm looking for a tuner in the
Dallas area. Oh, my 06 Springer has the same stage 1 as yours.
ORIGINAL: FLSTCI nut
Thanks for your responses. What is SERT and how much should it cost? Does the dealer install this? I am new to this. Any and all help is appreciated.
#1... Make sure that you have the CORRECT ECM Flash.......
More and more I am seeing work coming to our shop from other Dealers, and the incorrect ECM Flash is the culprit......
#2... What you are hearing is called "Lean Pop"...
Only happens on decel, and only out the exhaust......
Makes me think that you have the wrong flash.... You should have the Stage I Race flash, as you have SE Mufflers.....
Thanks Bob! I am going in on Wednesday for my 1000 mile service. Talked to the service manager and he said he would make sure the d/l was the correct one. Talked to another friend of a friend today and he recommended a Cobra fi 2000r. Any opinion of that piece of hardware?
Cobra is like a TFI/DFO, just a band-aid that sits between the Delphi and the injectors. I have the exact same set up as the OP's bike. I had a little lean pop when the bike was new, but after the 1000 mile service, pop was gone. Cause? loose exhaust connections. Once retorqued, the pop went away. Bike runs great with nothing more than stage 1 flash.
