SERT what one?
SERT what one?
Gents,
Before I go into my stealer I want to know what SERT I should get. I am not finding anything on Harleys web. However do they make one that is USB only. Anyone have part numbers or suggestions. Also I am thinking of installing it myself. Cant be any harder than a PCIII.
Does the CD come with a map for
stock 88A
25 Deg CVO Injectors
SE Filter
True Duel Rienharts
Central Florida
stock 88A
SE Filter
True Duel Rienharts
Central Florida
RE: SERT what one?
Part number for the SERT is 32107-01E. The one I got is a serial connection. I believe you can get a serial to USB convertor. It comes with cables and CD. On my St Bob all you do is pull electrical cover and plug in SERT and do your download unplug, put cover back on and you are done. It comes with some canned maps.
I got my SERT from www.zanottimotor.com for $357. Dealer was asking $459
RE: SERT what one?
You are NOT going to get a map that has anything that is NON-HARLEY in the software accompanying the SERT......
The SERT Software is merely a bunch of "Canned" maps that HD has developed for their Stage kits.....
The SERT gives YOU the ability to manipulate and Modify them to YOUR SPECIFIC NEEDS and desires........
