06 electric glide
06 electric glide
I have a bike that runs really good but every once in a while it misses for a couple of seconds clears up and could be 20 min into the ride or sometimes 3 -4 hours into the ride. No codes put new wires on ran fuel injector cleaner but still the same. I do not know if it is ignition or fuel.The bike was bought in Florida and rode 3500 miles trouble free and about 2000 miles in Ontario Canada .Any ideas would be helpfull Thanks Coupe36
discovered the problem
After some heavy research turned out to be the fuel line from the fuel pump to fuel filter had a tiny hole and would not hold proper psi.Could not find a Harley dealer that would sell just the hose and clamps so used fuel injector line and hose clamps .Bike runs perfect.Took about an hour to fix the problem.Hope this helps any one with sort of problem.Thanks again Coupe36
