I dont know sh**
I dont know sh**
But this cant be right. I have a 09 FXDC stage one.. SE filter V&H BSS.. PC V an the auto tuner... I get popping on decell.. But if Im just in the garage an rev it a bit get pop with a nice flame. So where to from here? I just want to ride. fk all this tuning crap... A little help guys. Suggestions?
Guess auto tune ain't what it's cracked up to be......
With what you are doing (Rev it up and release the throttle), you are richening it up and then shutting down the revs, but the extra fuel is unburnt, and finally ignites in the pipe... It is called decel pop....
You need to get the proper mapping for the decel popping to stop... Either your accel fuel is too high, or your 0% fuel is too low....
"From Power Commander site HD FAQ---Open the map you are currently using. In the 0% TP column from 2,000 RPM and higher enter a value of 20. Click upload and ride the bike. Often this is the only change that is required. You can also add a value of 10-15 in the 2% column from 3,000 RPM and higher (in addition to the 0% adjustment).
Also replace you exhaust gaskets, could be a leak there too.
Chris07
10-11-2013 11:59 AM
