Help!Anyone ever had this problem before?
anyone have this problem 99 roadking carb i ride for 10 or 15 min the bike shuts off like you hit the kill switch all lights and accesaries still work fine bike wont start again until you let it cool down for 15 or 20 min I checked for spark geeting no spark when this happens I ride again does the same thing after5 or 8 min I changed 50 amp circut breaker under seat bypassed bank angle senser still no luck STEELER says might be crank poss senser or ECM any ideas out there thanks ride safe dan05
Received 4,808 Likes
Your 1999 model has the check engine light....I would use this to your advantage.
If the check engine light is coming on....definately run for codes. This might help point you in the right direction.
I would grab the shop manual and start troubleshooting. Whatever you do, avoid just throwing parts at it.
theoanast
07-22-2010 01:51 AM
