TSM Key Fob
Hello
I had a problem with TSM and i decide to buy new one.
I bought new TSM system and i have next problem. I done everything what i saw in instruction but when i must click key fob - enything happened, any flashes nothing.. What i have to do ? Maybe u can help me..
Programing Note:
1: Set Run/Stop switch to off
2: Turn ign key ON-OFF-ON-OFF-ON
3: Press the left turn switch two times and release.
*The signals flash 3 times for. (international)
4: Press the right turn switch 1 time and release.
*The signals flash 1 time.
5: Press the left turn switch one time and release.
*The signals flash 2 times.
6: Press and hold key fob the signal should flashes.
=== Here enything did..
I am from Poland and i havent got communication with any dealer of HD. And my english can have some mistake (sry)..
HELP !
Programing Note:
HELP !
Just looked it up in my owners manual and yes, the first 3 flashes means Netherlands configuration TSSM (Dealer configurable only).
Now, are you reprograming your key fob to your new system? Or are you just trying to enter a new personal code as well? But I think you need to have your dealer take care of this since that's what it said in the manual.
That is new TSSM without any programed key fob or personal code, and key is new, bought with new tssm. And in instruction new tssm first step is programing key fob to tssm, next step is programing personal code, and next alarm programing.. 4 will be configuration tssm with ECM.
But i have problem in first step. When i try click key fob to programing
"6: Press and hold key fob the signal should flashes. "
Why ?
Why ?
what you are doing is assigning your key fob. in the book it says that each step must be completed within 10 seconds of the previous one (no more than 10 seconds between each step) Also, on the final step, you press and HOLD the key fob until confirmation is received.. PLEASE NOTE THIS AS IT MAY BE THE ANSWER... the comfirmation may take 10 to 25 seconds. maybe you are not holding the key fob button down for long enough. The only other thing I could think of is maybe the battery in the key fob is no good maybe it is not sending its signal
I did everything with instruction and i know that time and i analized it very good. I did all steps and everything was good without that key. I have 2 key fob and i try this and this.. nothing happened...
I read on TSSM frequency 433,xx MHZ is that only one frequency for key fob ?
assigning, battery, buttonless, code, davidson, fob, harley, harleydavidson, installation, key, keyless, marry, personal, programing, swap, tsm, tssm
