injectors/sert tunung
Old 06-05-2006, 04:32 PM
tnt's Avatar
tnt
tnt is offline
Default RE: injectors/sert tunung
I will try and thanks much.
Old 06-12-2006, 02:21 PM
tnt's Avatar
tnt
tnt is offline
Shovelhead Bob,
The map they said was used is #27
file 141NR101
S/E AC
Touring mufflers
1450
Old 06-20-2006, 12:57 AM
FLSTCI nut's Avatar
FLSTCI nut
FLSTCI nut is offline
TNT what kind of repairs are they talking about? The 25 degree injectors? An 06 with 1000 miles on it is a new bike.
Old 06-20-2006, 09:08 PM
tnt's Avatar
tnt
tnt is offline
No real repairs. They are still saying the bike runs fine with the 8* injectors. It seems to be running fairly good, but I need to load the SERT into my laptop and see if I can adjust the AF in the 2300-2500 range to knock off the decel pops in that range. It still idles a little rough when it is cold. I am looking at the maps and adjustments and it doesn't seem to be too difficult once I get the hang of it, but I imagine that that can be deceiving. I don't know if there is a better base map then the one they used.
If anyone has input, or ideas,please let me know.
Old 06-20-2006, 10:48 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Shovelhead Bob is offline
That is a weak MAP, in my opinion.....
For any stock 1450 with an AC and I am hoping that you have performance slip-on muffs, I would go with a 1550 Softail Stage I (Applicable injectors)....
I would use it as a starting point... Little fatter, and less adjustments needed for tunability....
Old 06-21-2006, 04:15 PM
tnt's Avatar
tnt
tnt is offline
Thanks, I will load it. But, since they already dyno tuned it, will the different map screw that up? I do have the slip ons.
Old 06-21-2006, 04:58 PM
Shovelhead Bob
It is going to completely change the map that is in there, and unfortunately, there is no way to save it, unless that map was saved to a disc prior to the tuner finishing it up....
Old 06-21-2006, 05:07 PM
Z6969's Avatar
Z6969
Z6969 is offline
I have a new o6 dyna want to put slip ons on. Can I use the POWER COMMANDER III USB or V/H Fuel pack and new A/C and leave it at that or do I need HD remapping also.
Thanks
Frank T
Old 06-21-2006, 05:17 PM
tnt's Avatar
tnt
tnt is offline
Well, it's probably well worth it. I will let you know. Thanks for the help, much appreciated.
Old 06-23-2006, 04:17 PM
SGLarry's Avatar
SGLarry
SGLarry is offline
Hi Bob, I'm new to the forum and posted in the New Member thread:
<<Just checkin' in as a new member here. Traded my 7 year old '99 Road Star in on a new Cobalt Blue Street Glide a month ago. 1600 miles and I'm enjoying the new SG a lot. Had the Stage 1, SERT, and V&H Dresser Duals and Ovals put before it was out the door. Had it in for the 1000k sevice and custom dyno-tune a couple of weeks ago. It seems to be running well so far even wth the 8* injectors ( the custom map has seemed clear up any drivability issues that I had, although I had hope for more hp) I like doing my own servicing so my 1rst purchase was the service manual. Just put in the HD Auto primary chain tensioner the other day for a start.<G> Oh yeah, I also adjusted the handlebars, what PITA! Had to get everyhing lined back up so I could get the ignition to side back in properly, but I finally got it. LOL! Looks like a lot of good folks, help and info here. I'm sure I'll back with questions, but for just going through post and soakin' up as much as I can. >>
I see you're in Greensburg. I'm in the Plum Boro near new Ken! From my intro you can see what I've got on the SG. I've got to say I'm kinda dissapointed with my dyno numbers from the dyno-tune that my "near-by" dealer did at 1k service. I actually had to hound them for a week to get the chart. I can see why, LOL! After spending close to $1500 for the Satge1, Sert and V&H dresser duals w/ ovals + a dyno tune, my top hosepower is 62.35 and torque is at 71.11. Isn't that pretty much the same as stock? They told me this was the final run. Since this is the first time I've ever had a bike dyno'd, I don't know what to think. Seems as though they used the nr101 map from the software. The bike does seem to run well and averaging about 45mpg. Should I leave well enough alone or do you think I can do better? Thanks for any suggestions. I'm gonna try to attach the .jpg of the chart.
Larry
[IMG]local://upfiles/14102/5F86D786CA3F4F9D837A11F90D08B265.jpg[/IMG]
JonnyD
05-13-2009 05:23 PM
07fat_boy
10-16-2008 11:33 AM
crock921
08-28-2007 08:18 AM
Rodman813
03-26-2007 05:15 AM
Streetrunner
11-24-2006 11:52 PM
Quick Reply: injectors/sert tunung
