SERT ?
RE: SERT ?
Yeah, making the mixture richer is a few places and adjusting the timing in other's will make the bike run slightly cooler but don't count on miracles. Even with a SERT and a richer mixture in the right places my bike still runs hot when the temps get over 95 degrees, I bought an oil cooler for a little more breathing room if I get stuck in stop and go traffic. I'm waiting for the cooler right now from the UPS truck and will be installing it tonight. Every little bit counts.
RE: SERT ?
ORIGINAL: KBFXDLI
If you are still having heat issues with your bike and your dealer can't find the problem you might consider another dealer who has a long term highly expereinced service staff. If your bike is still under warranty you should try another dealer.IMO.
RE: SERT ?
I will tell you what the dealer told me just last week. If you have ANY mods done to the exhaust or intake system of an 06 with fuel injection, you need some kind of fuel management. The 06's are running right on the lean side straight from the factory. My 06 Ultra ran hot and did not have any power from day one. I had Stage 1 and Rinehart Slip Ons put on and it got worse. Had the SERT installed and dynoed and now it runs great with no heat problems. JMTC
Yoman
Yoman
