TBW wiring?
I'm still not sure what connector you are referring to. What do the wires control that are going to the connector in question?
these are the TBW wires. I have the connectors that go inside the bars all connected again thanks to the previous post. Now I am trying to get the black connector at the very end of the TBW harness back into the black connector that plugs in under the fairing. When I disconnected it to get the bars off I had to pull all the wires out of that connector to get them thru the bars.
Thanks for the patience,
Are you using the stock sensor (with the green plug), or the sensor with extended wires purchased from HD?
The wires that come out of the sensor have two sets of three wires. The three wires in each set are Red, White and black. One set of the three wires is wrapped in Black, and the other in Yellow. The colors should match as shown below.
Black set of wires:
Red -> Brown
White -> Blue
Black -> Black
Yellow set of wires:
Red -> Red
White -> Purple
Black -> Violet
If this does not explain it clearly, PM me tomorrow and I will give you a phone number to call me at.
Black set of wires:
Red -> Brown
White -> Blue
Black -> Black
Red -> Red
White -> Purple
Black -> Violet
Thanks to everyone, I got this issue resolved.
Once I got the location of the wires for the black connector everything seems to be working jsut fine.
I did not have to get another sensor from HD. The extensions worked for me.
I soldered the green connector wires together and pulled into the bars, connected and it worked.
THANKS BERT!
THANKS BERT!
THANKS BERT!
THANKS BERT!
If it were me, I would still replace the TGS, just to be safe.
