Tmax map 401
Tmax map 401
I just loaded map 401 into the Tmax (open loop) and the bike is running great but is using considerably more fuel, which doesn't worry me too much because at least I know it's not running lean. I am wondering if anyone has used map 401 and what adjustments you have made, if any. Oh yeah, I have an 09 softail with SE mufflers and K&N filter.
As for the milage, you can bump the criuse range afrs to 14.2 which will help. If it will take an additional timing advance of 1-2 * in the same area, without pinging on roll on, this will help also. You should get mid 40s easy for mpg.
Ron
doorsidedown
06-25-2012 12:19 PM
stagolee
04-18-2008 07:46 PM
