bike wouldn't start
Pull your maxi fuse and starter relay out and see if there is any corrosion on the pins. Clean them up and apply a thin coat of dielectric grease and re-install. (I clean my entire fuse box every 2 years). Did you have the battery load tested? If not, try that as well. You can have a battery that shows good voltage but has a failed or broken plate and will fail the load test.
RoadKingAnni562
Electrical/Lighting/Alarm
04-25-2018 02:31 PM
