Custom maps for EFI
Custom maps for EFI
Let me start with my problem then I will get to my question. I have a slightly modified motor consisting of true dual exhaust, K&N AC, 103 CI with 103+ heads, S&S 510 gear driven cam, I started with pro super tuner then went to PC III. I have the problem that I think is very common, high heat and poor gas mileage. I have a 50mm throttle body I want to install which would require yet another remap and I am tired of paying for Dyno time. What luck would I have in going back to the pro super tuner with wide band o2 sensors, or would I have better luck staying with the PC III. I'm trying to reduce engine heat by tuning it out, is that a possibility?
Not a sales pitch at all. I dont sell them, and wont recommend someone that does. A million vendors sell them and I dont have single one that I like more than any other. You want me to answer your question, fine. Can you tune out engine heat, yes. Can you do it without the use of a dyno, yes. Will you achieve this with the PCIII, I dont believe so. Is a tuner that uses the wide band 02 sensors more likely to get you where you want to be, yes. AFIK the pro super tuner (that I know nothing about) and the TTS Mastertune are similar but the TTS allows you to control many more variables. You should research it.
Like I said, the TTS Mastertune will get you where you want to be, allow you to tune out engine heat, and make it all possible without ever having to get on a dyno. I dont give a **** if you buy one or not, its your bike, your headache, your decision.
Jim
You can tune out heat with a PCIII if you find a skilled tuner who does a lot of PC dyno work. But the TTS system is just newer technology and you can tune the bike yourself easier than with the PCIII. That's all.
galaxyfe
31
01-03-2015 06:32 PM
glide_n_around
10-01-2013 02:44 PM
