Anybody done Thundermax/AutoTune w V+H 2 into 1 Big Radius?
If you've got/know of an install of TMax/Autotune ECM and V+H 2 into 1 Big Radius (the curved 2-1, not the staight), then:
did the longer O2 sensors that screw into the header bungs fit ok? Or did you have to weld an angled bung fitting?
I've got '08 Softail Custom, all stock. Want to add TMax and V+H 2-1 BR. But TMax O2 sensors are longer than stock HD. I need to know if the longer sensors fit ok with the bung postion on the V+H and clearance on the 08 FSXTC.
Thanks
Thanks
11'heritage
03-06-2014 07:51 PM
