Spark Plug Wires
RE: Spark Plug Wires
ORIGINAL: Shovelhead Bob
Next time you go by a HD shop, ask them to validate and update your ICM.....
Or do it on your next svc (If you have the dealer do it), and TELL them to update it......
If yours hasn't been done, you are 2 versions behind.....
Bob can you explain this, what is the ICM???
Also, you talked about spark plugs, you mean to tell us that we have to run Harley Plugs only? From my understanding the HD plugs are made by champion, so why not just run champion plugs without the HD branding??
Bob
Try running Split-Fires, AC Delco, or any other brand.... They will screw up the ECM/ICM Tuning, and will pop a CEL..... Normally "No combustion Detected Rear Cyl"....
I do not know who manufactures them, but remember, the ECM/ICM has to monitor ENGINE PERFORMANCE... not our definition of performance....
Kinda like the Planetary alignment... Certain components HAVE to be used, or someting will go awry....
ICM is Ignition Control Module....
Starting in 04, HD Carb'd bikes have "Updateable/Programmable" ICM's that can be reflashed similiar to ECM's.....
