Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
the bike runs great but when i turn it off and let it sit for a few minuts it wont start when its hot, ill let it cool down and it will crank right up, i have 9000 miles on it and this is the first problem i have ever had. Any suggestions???
Is this like it won't turn over when hot or just won't fire up even though the starter is cranking just fine?
Ron
Clearly a heat soaked electrical problem, would be my first guess. Could be crank sensor, coil, or any other device used for ignition. Takes more to fire a cold sparkplug so I don't think it's them. Like both at the same time, not likely. Does you fuel pump cycle normally when hot, just to rule that out?
Ron
