SEST map for an 04 ultra w/HQ 113"
I don't know if the newer program will go into your 04 ECM BUT if not
What you can do is copy and paste. Set up the 04 program half screen and also the 07-08program you like.
There are some common tables I am sure. I would thing the VE tables and others would be useful.
If you like the hold table, right click at the upper left whick selects the whole page. Do this on both programs. Go to edit on the new program (07-08)and select "copy". Go to the program you want to improve (04) and select ,"Paste". If the things are different enought now to not allow you to do this you can still do one collom at a time.
Maks sure on the older program you change all the, Engine Constans to what you have. Will have to reset things like IAC and cranking fuel. Acceleration increaser needs upping. Reset all you can.
Use the newer program to give yourself guidlines for things that will be different. Remember there are some things to think about like injector size and such.
I think that will work.
Will be a learning process which is always good.
good luck
good luck
