99 Road King High Idle
I have 99 road King that start giving me slightly high idle when started and stay high. (It was high when I just start it and goes low after I blimp it a couple time).
The bike it self is running fine but I just dont feel it right when stopping and hearing the engine running high.
Can someone give me advise on how to adjust it?
Thanks in advance.
Thanks in advance.
You didn't say but I assume you have EFI. Is it running faster than the 950-1150 RPM value? If so, may want to get it checked since one of the sensors may be providing false inputs to the ECM and it's over-compensating the idle speed because of it. Check for any trouble codes in the self-test may also direct you to the problem. It may be just time for a periodic "tweak" of the ECM's idle speed, though.
Did you ever find out that the heck that means? Also, how did you fix the problem? Thanks! Matt.
When you do the speedometer button thingy you are only getting speedometer test codes.
Diagnostic mode: Ignition on and off three times. Wait for rapid flashing of check engine light to stop. Then count the slower flashing light to get the trouble code.
Best to clean the throttle body and the idle air bleed holes then reset the cold and hot idle speed with the two set screws on the bellcrank.
Thanks in advance.
Thanks in advance.
dinger_greg
Engine Mechanical Topics
06-15-2020 05:20 PM
