Code B1007? Help Plz
Just went for a ride on my bike and as I was riding the bike died and started up while i was riding, it did this like 5 times on the way into town, and like 5 times on the way back, it did it at like 50-60mph..So i got home and found that I had a Code..It says
B1007 Ignition Line Overvoltage Instruments
I have no idea what or where to start
Does anyone have a clue or has anyone ever pulled this code on their bike? I'm a little confused but I dont rly know what to do, Im going to give me HD Dealer a call tomorrow if I dont get some ideas plz
Most likely your voltage regulator quit working. It's the little box with the fins at the bottom of the down tubes on the frame, right in front of the oil filter. You can check it by measuring the voltage at the battery. With the bike running it should stay at about 14V. If it rises with engine speed then the voltage regulator isn't working. The B1007 means the voltage was over 16V for more than 5s. So it occasionally spikes to 14.3V isn't a problem, it stays at 15V until you let off the throttle is a problem.
Well I just checked with a voltage meter, and the highest the meter spiked to was 14.29, at first on the start up battery was at 12.48..so now I am back to square one..maybe there is some water in my connections to my Power Commander? and made it spike? I had gotten caught in a nice little downpour bout a week or so ago but i would imagine it would of did it that week as well?
Just did that as well, I found that the + side of the battery cables were loose and not so much the - side but I tightened them up again..I was also told it maybe a pinched wire underneath the tank? going to check for that hopefully tomorrow..My next question is if I fix the code would the code be gone if I checked it again or would I have to clear it first then see if it comes back?
follow up on this issue, help please
Any help would be greatly appreciated.
Regards,
--Jeff
2007 FXDWG, bone stock.
