Pc3
Pc3
A question for you tuner experts. I have a 07 Road King with the PC3 installed. What change can i make to my generic map to eliminate slight popping just as the bike is slowing to an idle as i decelerate in first gear.It doesn't pop at any other rpm when decellerating through the gears.Thanks for your input.
there was also a firmware upgrade to the PCIII to help an off idle hesitation which might be related to your issue. Several posts are here if you search for off idle hesitation. At the very least you could go the powercommander website and ensure you have the latest firmware installed to see if it helps.
05 HD Deluxe
04-27-2008 06:25 AM
bigblock455
17
11-26-2007 08:57 PM
