'98 Fat boy electrical problems.
On the last mile of a short trip, bike sputtered, lost power momentarily then continued on. It did this 3 or 4 times more. Pulled into the garage and the bike seemed like it was missing even more. Tried to keep it running, but it died. No power beyond ignition switch. Checked ignition switch and only the acc. side has continuity. also, do not have 12v on the pig tail connector to the switch. Battery connections on first check seemed tight enough. Also... There is a slight burnt smell around the underside of the ign. switch. just need a little direction. Thanks.
Tris S
General Topics/Tech Tips
05-15-2019 11:06 AM
Rugboy
09-03-2010 05:03 PM
