Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I read that in the manual but not sure if that is what is meant. You can use a previously used SERT and gather run data and read the ecm info so I am not convinced that the when you select that option that it writes anything back to it.
If thats the case then the manual is most certainly misleading. The way I read it. (I don't have a SERT to test) is that once the module is married it can't communicate with any other ECM.
