Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I don't think going from a 150 to a 160 is going to dramatically affect your tire circumference.
The real question is why. I could probably take a felt pen and write 160 on the side of your tire and you would notice the same difference as actually installing one.
Why-because the stock skinny tire is a joke. That's why HD put bigger tires on the 09's. The 160 is bigger and will fit and looks good. It also has a higher load rating 992#. One guy that put one on now said his speedo is now reading 10mph slower-he got a ticket. I need a new rear and I want the biggest I can put in, just want to know if TTS will correct the speed?
Ohh one more question if I have the dealer download the ABS revision on my 08, does it matter that I have a TTS canned map in there? Will I lose it or anything? Will the dealer "see" it?
The dealer should see that you don't have the original calibration file on your bike, but I have no idea what the ABS revision is. Consider asking the service tech and ensure you have a copy of your latest map.
