Bike won't start and bad clutch
Old 05-27-2009, 09:00 AM
alaskafatboy's Avatar
alaskafatboy
alaskafatboy is offline
Stage II
Default sorry
I appologize, i was in a hurry and could not figure out how to start a thread.
Old 05-27-2009, 09:03 AM
Zacharia_11's Avatar
Zacharia_11
Zacharia_11 is offline
No big deal, to start a thread just go to the appropiate section and look at the bottom left of the page. Should say 'New Thread'
Old 05-27-2009, 12:15 PM
Bent Wrench's Avatar
Bent Wrench
Bent Wrench is offline
Someone doesn't like VZE1 and has reversed his plug wires......
Old 05-27-2009, 12:23 PM
Zacharia_11
Who do you figure did it, his mom? That'll keep him off the bike...
Old 05-27-2009, 12:25 PM
VTwin-Goodies's Avatar
VTwin-Goodies
VTwin-Goodies is offline
Sponsor
Received 1,949 Likes on 1,933 Posts
that is a cruel trick to play on someone. If ti won't start start with the batter, spark plugs and wires, along with the starter and work you way through all of those things. For the clutch you might want to check the cable to make sure it is not broken. Adjust it. Go from there. I am sure those articles say to do the same.
__________________
Old 05-27-2009, 02:48 PM
Theo's Avatar
Theo
Theo is offline
Haha...I wish that's all it is, but unfortunately it's not. Just an update on the battery. I took it to autozone today to get it tested and the guy there said the battery is fine. But I decided to get a charger anyway. I got home and hooked up the battery to the charger but the charger says it's already charged and won't do anything. I checked the battery with a voltmeter and it says it's 12.54V. According to the owners manual, that means the battery is about 75% charged. I don't get it. Is the battery fine or do I have a bum charger?
Old 05-27-2009, 03:03 PM
Zacharia_11
12.54 is ok. This was going to be the easy one that would get you back out on the road with the least amount of messing around. Make sure all your connections are clean and get it back in the bike, use a wire brush if you have any corrosion. Also make sure you have a good gound connection to the bike.
Is the charger you got specifically for motorcycles?
Old 05-27-2009, 04:39 PM
Theo's Avatar
Theo
Theo is offline
Yeah that's what I thought. I'm still hoping that it is just the battery. The charger I got is this one.
Old 05-31-2009, 10:24 PM
Theo's Avatar
Theo
Theo is offline
So you were right Zacharia_11, it was the battery. You should have seen the smile on my face when it fired up. And the clutch worked fine after I got the bike started up. I guess it just needed to get some oil on it. Anyways, thank you so much, and if you are ever in NYC, let me know, I'll treat you to lunch or whatever. Anyways, thanks.
Old 05-31-2009, 10:40 PM
Zacharia_11
Glad to here it worked out! If you find it bails out on you again get a new battery, when their done they won't hold a charge very well.
awilson40
01-17-2014 03:22 PM
fishtown fatboy
08-26-2013 10:35 AM
Charlie81
General Topics/Tech Tips
12-04-2012 05:09 AM
amish
05-27-2009 09:06 AM
roadking1221
12-15-2008 08:42 AM
Quick Reply: Bike won't start and bad clutch
