PC III question
PC III question
I just put my PC III from Fuel Moto on my bike, do I need to do that closed TP adjustment or can I just let it go? How do you know if you need to do any adjustments to the TP?
I gave my laptop to my daughter so I don't have an easy way to check it right now. It started to rain when I got the PC on and it seems to run great just taking down the road a bit in the rain.
Just my 2cents, but it doesn't hurt to check(using the Power Commander Control Center) to see if the PC is showing "0" throttle once the bikes warmed up. If it isn't, you can set JUST the idle to "0" using the Power Commander tools section. The directions tell you how to set just the "0" , without reseting the 100% portion.
