bike popping at steady throttle?
Need some advice guys. I have an 06 dyna, 95" kit , thunderheader exhaust and a pc-III.
It has plenty of power, but, if im holding the throttle at a steady position while crusing in lower gears around town, the bike starts popping is the best way that i can describe it. It's not as sharp as a decel pop, but it does start to break up a bit. ITs also really noticiable when first taking off after warmup, it almost seems like its missing, but then goes away after a few minutes and again just breaks up if the throttle is held in a steady position. I did it more with the map that the dealer did after my build, Ive tried a different map, and it still does it but not as bad. Any thoughts on what might cause this? Should I add or take away fuel? Cant seem to find any exhaust or intake leaks so I'm leaning towards the map. Any help would be appreciated.
eddie
eddie
