Low Batt/High Volt Codes
Received 1,297 Likes
Coming home from work today my battery light and engine light came on at the same time. Only had a few miles to go, and bike was running fine, so I kept going. Checked the codes:
P0562 Battery Voltage Low EFI
B0563 Battery Voltage High TSM/TSSM
B1007 Ignition Line Over Voltage Instruments
Cleared the codes and started the bike with no further codes. Battery cables are tight, ground connection is tight, no corrosion anywhere.
Ideas?
Ideas?
I have been having a similar problem as well. Every time I start the bike, the check engine light comes back on for about ten to fifteen seconds, then goes out. Code for low battery voltage. Took the battery out and had it tested. Passed computer diagnostic and a seperate load test. Still does it every time I start it. Put a volt meter on it and it's charging fine.
Any one have an idea?
baka1969
07-20-2013 09:24 PM
DarkManC
15
07-02-2012 09:32 PM
DarkManC
07-10-2009 07:24 PM
