wiring 06 ultra, running lights
crampfan. can you tell me if you've done any upgrades lately to things such as the switch housings, etc. how about tattle tale signs such as it happens when you depress the brake levers, the clutch lever, etc.
the two things I would check right off the bat are the front running lights where they mount there are two wires coming from each light through the lamp assembly. make sure the wires are not pinched there. also check the switch housings as this seems to be a common place of locating pinched wiring. maybe a tie wrap came loose in the switch housing (left as you're sitting on the bike)
hope that helps
Todd
hope that helps
Todd
hope that helps
Todd
hope that helps
Todd
I need to see if anything else is on the circuit.
kjcalig
08-30-2011 09:31 AM
