IAT sensor ?
IAT sensor ?
I am getting a code P0113, which is IAT sensor open/high voltage. I have a couple questions. I haven't looked yet, but it may be loose and all I have to do is reconnect it. I have done some research and some of the fixes recommend cleaning the connection or even the sensor itself. What would you recommend cleaning it with, alcohol, electrical contact cleaner? If cleaning it doesn't do the trick hopefully these are an in-stock item at the local dealer. Bike runs fine as it seems to be an intermittent code, on and off every once in awhile. I'm sure my mixture is affected though due to whatever the default reading is. Any help is muchly appreciated. I also posted this in the Touring Section.
Jeff
Jeff
