Cam's and the PC-V.....
SERT/SEST/TTS are all excellent EFI controllers, but when you make hardware changes with these you'll need to perform a dyno-tune. If you studied DJ products (PC) before you purchased SERT you were looking at the PCIII, as the PCV or PCV-AT were not available at that time. The PCV-AT changes everything, IMO, and adding another piece of hardware is no functional limitation.
