Can you use an ied with a race fueler?
Because of the closed loop and open loop is it possible to use a race fueler for the open loop and an ied for the closed loop. I went a got a dyno run for a stage 1 down load and it was running lean 14.6 to 14. This is in closed loop. So I got a race fueler and one more dyno run in now is running around 13. to 12.5 not bad I can adjust it a little to get it perfect. I also ask the tuner to hold the idle at 3000 for a few seconds it read 14.7 to 15 and at ideal it was up to 18. To high! I was thinking could you use a ied injunction with a race fueler?
ummmmmmm, most dyno runs are done at wide open throttle in 4th gear. on any HD with O2 sensors, this is open loop (above 50% throttle) closed loop, where the o2 sensors affect AFR, that is idle and minimal throttle/ crusing........
best thing you can do is buy a super tuner or a powercommander and have the bike properly tuned on a dyno.
Personally I would buy a sert I had one before and it was the best, the problem was when I was downloading a change to the ecm my laptop died on me which fried the Harley ecm. Got a new ecm but did not want to spend the money on a new sert. The sert is the best because it was designed for the Harley ECM. The power commander you have to remove the 02 sensors which are a major advancement for Harley. Yes the engine runs hotter but then you get better mpgs and besides the new Harley engines is made to run hot.
kishstl
15
04-21-2014 11:55 AM
ccmdawg
03-30-2007 01:27 AM
