ECM and MAP questions
I purchased a used 2006 Superglide last spring. It popped and cracked alot, but ran real strong. I had it dynotuned from a guy that I later found out doesn't do a great job on Harleys. The popping and cracking were gone, but preformance was lost. Last fall I got a map from a member here that runs real strong, but it runs hotter than the previous map.
I have a PCIII usb, HD Hi-Flow Air Cleaner and V&H BSS exhaust.
My questions are:
1) How can I tell if I have a stock or stage 1 ECM?
2) Does anyone have a map that works for them with a similar set up, I could try?
Thanks,
Larry
My questions are:
Thanks,
Larry
Other Devices: downloaded map missing from my VH FP3
JZFloatingkent
The Dyno Room
05-16-2017 12:50 AM
neonhomer
04-27-2008 08:21 PM
