PC lllr help needed!
1 Post
I hope someone can help me, I've got a 01 RK with a PClllr with a 95" kit (S&S) pistons, SE ac, 510 gear drive cams, V&H ovals slip-ons. I have had some serious pinging upon acceleration and want to change the ing. table on the map. The only problem is I cannot retrieve the orignal map. I loaded the 000 map, then click open and then click get all' I get a message: file and powercammander not compatible. I have retrieved the map before and saved it but it does not show the ing. table values. So I thought I would get it new again. Any Ideas? I have installed PC on other scoots and loaded maps with out any problems, but they were PC usb. This one being older, maybe I'm doing something wrong? I follow the usual procedures, even running the engine but no map. I know the current map was modified by the last owner when it was dynoed but he couldn't remember if the ing. tables were modified.
Anyway, anyone have some thoughts?
Thanks
Thanks
If you are using the program for the PCIIIusb, you may want to try and load the older version program. I had a problem like that with my 01' Ultra. I downloaded the newer program, and it wouldn't work with my PCIIIr. The older program works for pre USB models. The newer programs will work with the older maps, but it converts them to a different format to use.
Just go to dynojets website and download the older program for the PCIIIr.
1 Post
Justinf74
02-27-2012 08:30 PM
