race tuner maps
Buy the software... That is the only way you will be able to access the ECM, let alone install a canned map...
Providing that you are just installing a simple set of mufflers, you probably are correct, that a canned Race map can handle what you need... If you are installing a complete exhaust system (V&H, BUB, Reinhart, etc...), then you might want to find a good COMPETENT tuner, to dial it in...
Sorry to hear that the dealership you go to has beasts of burden in the service department....
