Battery cranking amps
Old 03-29-2009 | 07:44 PM
Howard's Avatar
Howard
Default Battery cranking amps
I have a 04 Roadking the battery gave up, it was rated a 385 cranking amps. I bought a after market battery that was rated at 450 cranking amps. Qustion will this new battery cause me any electricial trouble by being 450 cranking amps?
Old 03-30-2009 | 12:23 PM
Crazycalvin's Avatar
Crazycalvin
No it should not. An electric/electronic circuit will only pull as much current as it needs. Needs will vary depending on the "load" that is connected. Later, Calvin.
Old 03-30-2009 | 06:38 PM
Pine Tree's Avatar
Pine Tree
MODERATOR
Veteran: Marine Corp
Originally Posted by Howard
...Qustion will this new battery cause me any electricial trouble by being 450 cranking amps?
As stated above, no.
FWIW, some batteries are "CCA" rated at 0 degrees F and some at 32 degrees F...not that you need to be concerned with those numbers once spring/summer gets here.
13RoadKing
Electrical/Lighting/Alarm
02-11-2017 03:31 PM
Buckinfitch
02-21-2012 10:02 AM
TestFlyer
07-06-2009 04:07 PM
pd76
EVO
13
02-14-2009 11:30 PM
HDF Tech
12-12-2005 09:45 PM
