Blown Fuse... strange
I got home from work yesterday and my left side blinkers do not work, so I check the wiring the one wire from the hand controls was cut between the light housing and the gas tank, so I clean it up solder it back together and tape the crap out of it since I have no shrink wrap or anything (temp fix while I am saving up for me new headlight) anyways that is all fixed up so a couple of hours later I go out to head to a PGR hand out thing I start it up no prob, begin to roll it out of the garage and it just dies. no stutter no hicup, cough or anything just bam dead. I try the start and nothing at all happens no click or anything.
So I push it back in the garage check the wiring that I had just played with earlier and there are no exposed wires anywhere that could have ground out or anything so I pull off the seat take a look at the fuses and sure enough the fuse for the ignition is blown.
Now my quesiton is does anything think the two might be related? Does it sound liek it was just the fuses' time to go? Are these the signs of bad things to come?
After I found the fuse I replaced and we rode to Knuckleheads hung out for a while and rode home no problems, I rode it to work today, back home for lunch and around the base, no problems.
I am leaning toward it was just that fuses time to go, but would love some electrical experts to give their opinions as that has always been my weak side.
Thank you all in advance.
You kind of lost me there.
But thank you for replying at least I see someone is looking in on it LOL
ArleeD
05-16-2012 09:25 AM
