Starting problems, starter dead
I have a softail custom chopper, bought it used. The wireing system wes a mess, home wired hack job. My battery was low, so on the bad advice from a friend, I jumped it from my van. Fried the solenoid points, also they were worn. I put in a new rebuild kit and a new battery. Took a while to figure out the wireing to the relays, but finally got it started. Took it for a short ride, got back, it smelld like something burning. Next day I tried to start it, almost started, then heard what sounded like a short, then nothing! Solenoid does not even click. Checking wiring, I noticed that the bolt that holds a contact in the solenoid and comes through the case to hook on the battery cable is touching the oil tank. Could this have caused the short? Or could I have hooked the wires up in wrong combination to the relays? I have lights and battery, but nothing from the starter, no click ar anything form the solenoid.
kawner.b
05-15-2012 01:28 PM
