What would happen if you disconnect the o2 sensors?
Old 03-20-2009 | 02:11 AM
ubreal's Avatar
ubreal
Default What would happen if you disconnect the o2 sensors?
Would the bike automatically switch to the open loop mode and run rich?
Old 03-20-2009 | 08:07 AM
harleytuner's Avatar
harleytuner
YEah, it won't run right and it will through a code.
Old 03-20-2009 | 01:49 PM
iclick's Avatar
iclick
Will run in open-loop mode and throw a code. Will probably run fine, though, although lean like before.
Old 03-20-2009 | 02:41 PM
LilBudyWizer's Avatar
LilBudyWizer
I believe the primary purpose is to adapt to the fuel. The closed loop will correct for other sources of variation but the fuel is the biggest variable. Gasohol has oxygen and gasoline doesn't. So that alters the mass of fuel you need given a mass of air for a complete burn since you may or may not be getting oxygen from the fuel in addition to the air.
13RoadKing
Dyno Charts
03-10-2017 11:24 PM
LonewolfFrank
11-16-2015 09:23 AM
LonewolfFrank
11-15-2015 09:00 PM
SmittyFXDL
04-23-2015 12:49 PM
RoadTramp113
03-18-2009 10:40 PM
