Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Over the winter I have purchased a LED light kit , pro pad mini beast air horn , and also A garmin Zumo 450. MY big qustion will the battery and the terminals be able to handle all the connections?
Any help would be awesome.
Shouldn't be a problem. The easiest way to be sure is check the voltage across the battery terminals. Check with the bike turned off and then running. As long as the voltage is higher running than turned off you are charging the battery. It should be around 12V when not running and up around 14V when running. If you haven't installed the parts check before and after. I doubt you would see a change, but as long as you are in the mid to upper 13's you're fine.
