AFR in Open loop
Old 03-11-2009, 11:57 AM
jluvs2ride's Avatar
jluvs2ride
jluvs2ride is offline
Location: Back in the Good Ole USA. South Carolina to be exact.
Originally Posted by rjmac53
boy do i feel like a moron...
I don't get it.
Old 03-11-2009, 12:20 PM
Steve Cole's Avatar
Steve Cole
Steve Cole is offline
HD EFI Guru
Received 3,688 Likes on 1,670 Posts
Originally Posted by LilBudyWizer
Hum, well, looking at the manual it says the VE New is what should be in the VE Table based upon feed back from the O2 sensors. So I guess it is valid to use that way.
If this is what the manual says it's wrong. VE new is not what should be in any one cell and it's only valid during closed loop operation under light throttle when the system has some feedback from the O2 sensor. It is invalid during much of the time like when AE occurs, or DE occurs and on and on.
V-tune takes all the collected data and uses that to generate a new calibration for you. All you do is give it a file name and program the new calibration back into the ECM. Takes all the guess work out of it for you!
oleboy
19
04-04-2016 08:09 PM
marty442
Exhaust System Topics
01-14-2011 05:55 PM
scatpac1
09-19-2009 02:34 AM
jakazz
15
11-05-2006 06:41 PM
DTK
09-21-2006 11:10 PM
Quick Reply: AFR in Open loop
