Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
will this #32107-01E s/e race tuner work on a 07 super glide custom or do I need someother model ? Thank's guy's for your input I can buy this one pretty reasonable and then just find somone to flash it !
If that SERT has been used on another bike then the module is "married" to the vin number on the bike it was first used on. The SERT is only good for one vin number. I have that SERT and upgraded to the v477 software so I will check the stock maps to see if they cover the 07 96 motor. Yes you can use that SERT as long as you use the v477 software upgrade. You will use this map for a stage 1.
Calibration # 67: 2007 - 2008 'All Market' Shotgun / Shorty Dual Exhaust with O2 Sensors
Configuration: 1580 SE A/C & Race Exhaust
File Name: 176AE104-A0.MT6
Components:
• 25deg Injectors P/N 27709-06
• SE Air Cleaner and Breather Kit P/N 29440-99C
• Race Exhaust
If you get the SERT but can't find the v477 upgrade PM me and I'll find you a copy. Very easy to install.
Jessie - I think I remember reading that the PC-V is for 2009 and later bikes only. I remember this because I have a 2008 Cross Bones and it won't work for me...
